Lumped port
Do i have to use some particular dimension when i use a lumped port? I mean do i have to use a particular hport an wport ratio?
Nicola
4 Replies Last Post Oct 26, 2012, 3:39 a.m. EDT
Posted: 1 decade ago Oct 25, 2012, 6:00 a.m. EDT
check the documentation if you need a user-defined port for your model. In many cases you can use a uniform or coaxial port.
Cheers
Edgar
Hi, check the documentation if you need a user-defined port for your model. In many cases you can use a uniform or coaxial port. Cheers Edgar
Posted: 1 decade ago Oct 25, 2012, 7:49 a.m. EDT
I'm using a user-defined option because i'm simulating an inductor that works in AC with a frequency of about 20kHz. So for that reason i use a impadence boundary condiction for the surface on my inductor and i use a lumped port for the current generation. I would like to know if there are some standard dimensions for the lumped port that i need to use or one random doesn't change the final result? for example in my model now i'm using hport=96mm and wport=120mm are they corret or other values are more correct?
Nicola
I'm using a user-defined option because i'm simulating an inductor that works in AC with a frequency of about 20kHz. So for that reason i use a impadence boundary condiction for the surface on my inductor and i use a lumped port for the current generation. I would like to know if there are some standard dimensions for the lumped port that i need to use or one random doesn't change the final result? for example in my model now i'm using hport=96mm and wport=120mm are they corret or other values are more correct? Thanks Nicola
Posted: 1 decade ago Oct 26, 2012, 2:55 a.m. EDT
answers???
answers???
Posted: 1 decade ago Oct 26, 2012, 3:39 a.m. EDT
It depends on your model. The port must be much smaller than the wavelength.
